I’m rebuilding a circuit board nearly 30 years old .
The and resistors are 1K marked 1001.
Im assuming they are 5% tolorance .
They measure 0.958 on my meter while the others read 0.995.
Wondering if I should replace the resistors that are reading lower in value or if they are ok ?
4 digits are generally 1%.
What amp?
How are they being used?
For 1%, the 0.958 is out of tolerance so it should be replaced.
What amp?
It’s an EQ card for the Rockford Fosgate Symmertry .
Im checking everything on the eq card and the main board since the unit is old and when it was installed the unit didn’t really do much .
The factory Bose system in my truck sounded better then the new headunit , symmetry and new components and amps
