REQUEST FOR OPINIONS
As I see from the description/data sheet, this PFC (power factor correction module), and not stabilized power supply.
You will need forward DC-DC converter like HyperTFS in order to get finished stabilized power supply.
Sorry to disappoint you.
Nice! One thing to be aware of is that many switchers require a minimum load in order to regulate the output voltage. It doesn't say in the datasheet for the Astec you found, though, there's a hint in the "Vout = 393 V @ 0.1 A" spec. Whether 0.1 A is the minimum or not would be a question for the applications engineer at Astec. It would also be nice to know the switching frequency, though, it's probably safe to assume that it's outside the audio band. Output ripple voltage would be nice to know as well.
The writing on the module itself labels it as a "PFC Module" i.e. Power Factor Correction Module. This explains the somewhat odd output voltage and why the output ripple isn't specified. I bet this module is intended to be used with a voltage regulator after the module to regulate to the final output voltage. This module only ensures that the power factor is as close to 1.0 as possible, it doesn't actually provide tight regulation of the output voltage. You could probably use a linear regulator after this module and have a quite good power supply, though. But that's a guess.
Also, beware that even with 90+ % efficiency, some 70 W will still be dissipated in the module. You'll need to get rid of this somehow, so a heatsink is definitely needed.
~Tom
I would be putting all the SMPS in a separate box underneath the amp chassis with an integral fan like in a desktop PC. Connection would be with a suitable Anderson Connector.
PFC (power factor correction module) is NOT stabilized power supply, its an add-on for DC-DC converter, its purpose is to make load circuitry to appear as resistive.
PFC module must be accomplished with DC-DC converters like the ones listed at the Astec Emerson Power web site:
Emerson | Embedded Power | High Voltage DC-DC Converters
The biggest problem with these PFC units (in general) is that they lack isolation from power line input to output. (they are just a boost converter, which is an inductor from input to output, plus a switch after the L to the other polarity side) Check the datasheets given for this unit, under I/O isolation it says "none". They also lack energy storage on the input side for the zero crossing times of the AC input, so they have significant line ripple when loaded.
Oops, didn't see that. Back to the search. 😎
well there ok but the one thing I have encountered with them is heavy emi filtering is needed on the input. It seems better to run the normal complement of capacitors plus putting some .01 across the caps to help clean up the noisy DC. I just get a good transformer because its a little less expensive after spending more $$ in supplemental components.
plus its surface mount technology, which means it probably last only 3-5 years.
