Hi Folks, I have been reading through old threads regarding converting tube pa amps to guitar amps. I have a few of these and have a friend teaching me how to repair them. He is not a guitar guy though, more of a radio guy. My question is this, can I just rewire the tone section to a fender or marshall type tone circuit without worry of causing the amp to be unstable. I have bogen mx-60 and mx-60a that I have repaired and work great but now i want to tweak them to get a nicer tone. I am just worried that if i change to a fender tone circuit, I might create some problems unwittingly. Any help is greatly appreciated. I will include a schematic for the mx-60a but I can't find one for the mx-60 so if anyone has one I would be gratefull for a copy.
thank you all very much
Brett
Brett
Is that the Bogen with a PP 807 output section? Dual rectifiers and weight about 9000 lbs?
I might have the schematic out in my garage with the same unit.
I'll check later.
Trout
I'll check later.
Trout
Hi Trout, the bogen mx-60 has 3 rectifiers ( gz34 I believe ) and a pair of 7027's in pp. Mine only weighs 8943 lbs! the mx-60a has a pair of 8417's in pp and a ss rectifier. I find these to be very good amps with heavy iron and very loud. I'm just not sure if I can arbitrarily change the tone stack without having any adverse consequences on the rest of the circuit. If you have any bogen or fanon schematics I would be most grateful for a copy.
Brett
Brett
I would be interested in any info you find out on this as I just picked up a Bogen MX60 as a project head for guitar. My amp has 6l6s in it. Jim
Provided you don't try and put the tone stack inside the global feedback loop, you should be fine.
