Hello Guys,
I have an Audio Alchemy DDE 3.0 dac and I´m thinking abou some upgrades to improve the sound a bit.
I´m thinkng about replacing the digital receiver/decoder CS8412 with CS8414, that´s even pin compatible.
As far as I´ve noticed the biggest trick is that CS8412 in the AA is DIP and the CS8414 is SOIC.
Besides worrying about that, that the only thing I WOULD have to change is the RC of the FILT to the analog ground.
I got 2 questions :
1 - Would the SOIC mount fit somehow in a DIP socket ? (It seems DIP is almost 3 mm wider)
2 - Would this "upgrade" give me any improvements at all in the sound quality, since the "dac" itself is a newer design ?
T.I.A.
Mauricio
I got 2 questions :
T.I.A.
Mauricio
Guys, if you got any other ideias for improving this DAC, I would also appreciate, since I´m not that confident this mod I suggested will be of great improvement in sound quality.
I like this DDE 3.0 a lot and I´m trying to give ir a few more years "on the job".
I´m also thinking about replacing some caps in the analog section. AA uses nichicon caps all over. Are these too cheap ? Would some Blackgates be a big improvement ?
Since I also got a DTI Pro32, I´m not really thinking about reclocking this dac. Should I ?
Tks again.
Mauricio
Tks again.
Mauricio
DAC3.0
I own a DAC- in the box and I changed its CS8412 to CS 8414
it works and pin compartable. Due to lower jitter of 8414
the sound after changing is better and can lock DVD sound signal.
I recommend you to do this
P.S I have a socket to convert 8414 to DIP pin
LEO
LEO
Leo,
Great news. 😀
Do you know any online place I could look for a socket like that ?
Tks
Guys, the signals CS8412 and CS8414 outputs by the pins 2, 3 and 27 (Cc, CD & Cf) are for monitoring the lock frequency only, right ?
Great news. 😀
Tks
SO or TSSOP to 28-pin DIP Adapter
I just bought a pair of Narrow/wide SO or TSSOP to 28-pin DIP Adapters at: http://www.brndog.com/index.html
Ivan
Ivan
