Anyone have any suggestions, hazards, horrors stories about how to safely replace a 2032 Lithium battery that's soldered to a circuit board between two clips? What safety equipment do I need? Safety glasses? Full face shield? HazMat gear? Bomb squad gear? What size soldering iron should I use? Anyone got any practical suggestions? Is there any risk at all or is my concern for no good reason?
Interesting video for attaching solder tabs to a battery. Hint, put them in the freezer before each solder connection to prevent the electrolyte from overheating. Use a large gun for fast heat. Gloves and a face shield are a good idea.
Replacing solder tab batteries
Remove the clips NOT the battery !
Replace the clips with a socket.
http://www.ebay.co.uk/itm/CMOS-BATT...ther_Computing_Networking&hash=item4d09114716
Vertical ones are also available.
CMOS BATTERY HOLDER / SOCKET FOR TYPES CR2032, CR2035 | eBay
That's a great idea. My problem is getting the old one out. I've have several chassis of the same type and on a practice one which had other problems as well....I broke the top tab off. I can still solder to what's left of it though. The bottom conductor seems to be attached to the circuit board, the top one seems like a spring. I didn't even realize until I tried to remove the old battery that it was actually soldered in. It seems like a battery holder even without the solder.
