Replacement transistors for Hitachi hma-8300
Hello,
I am currently repairing a hma-8300 hitachi and the power transistors are hs and not found in originals . Did you know an equivalent of 2sd675 2sd676 and 2sb655 2sb656? there are these 4 transistors mounted on each channel.
Cordialy
Steven
Compare Ft of the original and MJ150xx types - that's the speed and gain product. The Onsemi types may not have enough gain as Hfe-1 is a minimum 20 versus 60 for Hitachi or ISC (Inchange) product. It may work but perhaps not 100%.
If this is a pro. repair, I'd give the customer the option to choose the ISC replacement part or a substitute.
