A diy monitor box from a friend with Scan-Speak dome tweeter D2905 without ferrofluid and the above mentioned Bass midrange driver need service.
The LF-5 is faulty on both channels - both overloaded voice coil and and adhesive connection between rubber surround (suspension) and TPX cone/diaphragm damaged.
Which replacement comes closest to this chassis regarding sonic character (which was excellent in genuine resp. working condition) ?
Maybe the PHL 900? - go to post # 28 under
Error 404 - Page Missing
or KEF B110 SP1003
KEF B110 REPLACEMENT SP1003. FALCON B110 8 ohm. MATCHED PAIR. MADE IN UK.
A second question: Which company has specialized in the repair of these chassis with TPX membrane (also the LF-8)?
Thank you for your advices.
Some URLs:
Vintage Speaker drivers
Hifisound Der Spezialist fur Lautsprecherchassis
hifisound - Katalog 97/98
http://www.hifi-forum.de/viewthread-104-21059.html
https://www.analog-forum.de/wbboard/index.php?thread/43337-harbeth-spendor-co-thread/&pageNo=22
https://www.hifisound.de/de/Historie/
https://store.acousticsounds.com/PDF/Harbeth-Feature-Article.pdf
https://harbeth.co.uk/harbeths-history-in-speaker-cone-research/
https://www.inputaudio.de/wp-content/uploads/2015/06/Hifi_Ch.HL5__4_stars.pdf
http://audioconnection.se/res/HarbethAudiobrochure/harbethflyer.pdf
P.S.: this thread don't provide the wanted information:
https://www.diyaudio.com/forums/multi-way/229388-harbeth-hl-mk2-replacement-drivers-re-cone.html
or KEF B110 SP1003
Some URLs:
