Try the Fairchild KSC1815/KSA1015 complementary pair, or the KSC1845/KSA992 if collector current is low enough.
Dale
Dale
What is the application or a schematic would help.
For mic preamp
Is this an original new design, where you can specify supply voltage and transistor operating point, or is this transistor going into an existing piece of equipment?For mic preamp
You should be able to find one of these in your country, mpsa18, bc337-40, 2sc2240.
dchisholm question is relevant though.
try 2SC458 or 2SC945, I have try with this tr for mic preampFor mic preamp
- Replacement for 2SC1815BL
