Replacement diaphrams
You genuinely want 500 watt midrange compression drivers? Or you want compression driver for a cabinet rated for 500 watts. (Most of the power to a cab goes to the woofers.) And even then, cabinets are often rated for 500 watts "music power" or some such, when their actual power handling capability is a lot lower.
And by diaphragm, it sounds like you mean the whole driver, not just the diaphragm out of one, is that correct?
Might be useful to know what yo0ur entire speaker setup comprises.
