Good morning.
I have the Acoustats Monitor 4.
Would it be possible to use a tube other than the 6HB5?
If so where can I find the instructions?
Thank you all
Thank you all
In case the amps have not been “modified to death” the tubes last ages in these amps. No need to look for equivalents just make sure your amps are in excellent condition and do not eat tubes for lunch. In that case other tubes will have a similar fate in these amps.
Since I was mentioned above, I will tell you that I don't know what tube would make a suitable replacement. I'm not an expert on the servocharge amp.
In another post, member mark100 says he's using tube 6GE5 in his servos. Just repeating what I read, I have not verified this tube's suitability.
