hi all........just wondering if you can fix foam surrounds at all without replacement............l was installing some new sub drivers the other day and one of the screws slipped sideways and l hit the foam surround slightly causing a slight scratch in it...🙁
l'm concerned over time this might tear open with the surround flexing....is there any glue l could use on this at all??.....any help would be appreciated as l got these from overseas and dont want to have to get a kit if l dont have to........cheers ken
If the foam is split use a small amount of something like "copydex" to close it.
http://www.ryman.co.uk/Copydex-Adhesive-with-brush-125ml-Bottle-0625102293.asp
🙂/sreten.
🙂/sreten.
And remember to encircle the screw with your hand (make a fist around) to avoid this in the future. Sorry you had to learn the hard way. Good luck with the repair
Joined 2002
sreten said:Hi,
thanks......yeah it's not split....just a a small scratch,but over time might get worse .....so l'll check out this stuff and some others too that have been recommended.thanks again
🙂/sreten.
Cal Weldon [/i] [B]And remember to encircle the screw with your hand (make a fist around) to avoid this in the future. Sorry you had to learn the hard way. Good luck with the repair [/B][/QUOTE] LOL.yeah my bad.......l've installed drivers before and should've known better.......cheers ken [QUOTE][i]Originally posted by jleaman said:I use clear silicone. Works well. 😀
l'll look into this as well.....guess l'm just concerned on what might react with the surround material....cheers ken
Joined 2002
The reason i use silicon is because it wont harden or crack It remains flexible A little stiffer than the foam but if you use a small amount of it on the rear of the surround it should be fine.
jleaman said:
The reason i use silicon is because it wont harden or crack It remains flexible A little stiffer than the foam but if you use a small amount of it on the rear of the surround it should be fine. [/QUOTE
the scratch is on the front of the surround , so l'll have to use the stuff sparingly .....thanx ken
- Subwoofers
- repairing scratch in foam surround
