Remote turn on on amp
The remote-turn-on lead of your head unit. Generally a blue wire. Or, if it doesn't have one, I suppose you could just run it to any switched 12+Volt source so that it turns on when the key is in the acc or on position. By connecting it to the head unit's remote turn on lead, you can turn the amps off when the deck is off.
