Regulated PS for LM3875
Well if you showed some pictures, and the circuit you used, we may be able to offer some help.
Incorrect voltage with that circuit is down to either getting the resistor values wrong, or having a short somewhere. That's why a picture would help us to help you! 😉
Re-made one board. Very slight (0.8v) mis-match between rails, but no DC on turn-on, but a delayed pop/muted thump.
This time I have gone for Nuuk's version of the Filipe PS. I note that CF uses a resistor before the caps, but that is omitted in the Nuuk simpler version. Could this account for the delayed thump?
0.8v won't matter much Puffin.
I used the LM338 regulated supply with my LM33886 amp and didn't get any thump.
Update: I find that the best way to learn is to make mistakes. I was still not out of the water following my previous post. however after a little rearranging I got virtually equal volts on both rails and no DC. After the third rearranging, the penny then dropped as to how the thing really worked.
So, I have now made a pair and installed them. No "boutique" parts, just bog-standard caps and resistors. Initial impressions. Slightly less detail than before, but the jury's out as to whether that is really so, or whether the signal is cleaner. I had previously only been using caps on the chip, and only a bridge rectifier after the tranny. However I think I am getting more music. A more robust presentation. It's early days, but it is certainly no worse than before. No thump/pop on start-up either
