Rega Planet "power-out"
Hello
I have a strange problem with my Rega Planet CD-player (first generation) that I hope you can help me with. In the middle of playing a track all power seems to be cut off and the CD-player seems to reset. The display and power-on light goes dark and the CD stops playing and then after a brief moment the CD-player starts up again just like a regular power-on by pressing the power button (CD spins, track information is gathered etc.). If I press play again the same thing happens. Anyone know what may cause this problem? I’m no electrician or DIY fanatic, but I am hoping this is something I can fix myself. So far I have opened the case and looked at the mains fuse, which seems to be ok.
I've only got 3 hours to fix the CD-player, the player being at my parents house and me going back to my university-city tonight, so any quick suggestions would be much appreciated.
Thanks in advance
I didn't know, but since it was my first post it took a couple of hours to get it moderated.. Bummer.. I ended up bringing the Planet to my university city so suggestions are still appreciated.
When my father first told me about the problem he said that the player would play for maybe a couple of tracks and then stop. I first thought it might have to do with the motor moving the laser, some dust or something stopping the motor and thus stopping the playback. When I got home this weekend I did some tests which made me rule out the motor. I could skip through all of the tracks on a CD without anything happening, the playback first stopped a short time after I had stopped skipping tracks. I also tried playing a random track and then hitting the pause button, the disk kept spinning but at least the motor shouldn't be moving(?). Same thing happened on the "pause tests", the disk spun for a little while then the player turned off and on again. On one of the pause tests, playing track 11 of a 16 track CD, the CD kept spinning for about one hour, I changed track and after a few minutes the player turned off and on again.
I would check very carefully for poor soldered joints in the PSU. Particularly any regulators or power transistors.
The clue is you say it "resets" and the power light goes dark. That all points to a PSU problem.
Try gently prodding the board with it playing ( be careful of any live parts ) to see if the fault is physical.
I've repaired quite a few early planets with this fault. The cure is to replace the 4 (four) 1n4003 rectifier diodes making up the bridge of the main +/- 12 v power supply. These are located near the main power switch and the green fuses near there. I replace them with better fast rise time shottky diodes. Check the security of the filter caps solder joints while you're in there, better yet, replace with higher quality versions.
Thank you both Mooly and BEAR-K
I was hoping this was a known problem with the Planet with an easy fix, which it probably is for someone with more technical insight than me. I located the 4 rectifier diodes but I wouldn't know exactly which type to replace them with. The filter caps I didn't even manage to locate🙂 To ensure I don't mess up my Planet it's probably best just to get it fixed, or find someone with more experience who can help me.
If anyone is interested I uploaded an image of the circuit board to my flickr-account.
Up to you, changing the diodes is easy. 1N4003 are a standard 1 amp rectifier. Use 1N4004 get them anywhere, or BY127 or BY133.
You can remove them by just snipping each one out ( make note of which way round first) and with tweezers unsolder each bit of wire left in the board. Look for any joints that appear "dull" and cracked. The filter caps are those blue? cans next to the diodes. Check for dry joints on what looks like a regulator ( thing on a metal heatsink )
Good luck 🙂 Just work slowly and if you undo any connectors don't tug the wires.
What a wonderful thing web sites such as this are, my Planet has been cutting out for the last week or so. A trip to Maplins this morning for some rectifiers, ten minutes with the soldering iron and now it's back in business. Thanks for posting this info.
Bob
Hi There,
I had the same problem with my Rega plannet last year and I had to stop using it finally, Tried to contact Rega to repair the CD witout any luck. Tried few specialist Hifi dealers and answer was at leat this will cost £100 minimun just to send it to Rega for repair.
I tried your instructions as above and replaced the 4 diodes IN4003 from Maplin ( Only costs 64P for all 4) and here we go, it works briliant now.
Thanks you all for this valuable advise, without it I would be spending 100's of pounds.
Hi everyone,
I had the same problem with my Rega plannet CD player year ago and had to give up using the CD. Contacted Rega for the possible advise and possibly to get it repaired, but did not get any reply or help.
Contacted Rega dealers in the area and they suggested that least it will cost £100, just to send this to Rega for repair.
Finally I saw your advice and, yesterday I changed all the IN4003 diodes as suggested, Bought from Maplin (costs on 68P for all 4 of them) here we go player is now working brilliantly. I would have spent £ 100’s if your advice weren’t there.
I would like to tank all you guys and the forum for the advice!!
Interesting this topic came alive today.
Yesterday I was modding (again) my Rega Planet (2000 version). I replaced both voltage regulator capacitors. I'm waiting to the schottkys to arrive to replace the original standard diodes.
I have made a lot of mods in my Planet and never seen anyone interested on that. I have a lot of information and pictures about the mods and I can share here the ideas if somebody is interested.
thanks
Highef
thanks!!
@joostein - Thanks for starting this thread, it really saved the day for me and my Planet.
@BEAR-K and Mooly - Thanks for the great advice! How on earth did anyone ever figure out this fix?
@highef - Share your mods!
My Planet was powering out randomly and often, starting a few years ago...and for a time wouldn't power on at all. I was --><-- close to pitching it when I gave it one last try to power-on, and it did....so I kept it around thinking maybe there was hope. As it turned out, thanks to you all, there was hope!
I replaced the 4 diodes last night and after a day of testing it seems to be working perfectly again.
Hats-off to you all! :superman:
--LouMinaughty
Which diode for the Planet
Hello Everyone,
I read you posts with major interest as my Planet (1st version) is suffering from the same symptoms.
In one of the first posts, Bear-K, you mention that you replaced the diodes with "better fast rise time Schottky diodes".
Mooly, you suggested replacing the 1N4003 with 1N4004, which are (to my understanding) similar to 1N4003 but can stand higher reverse voltage... but which are not Shottkies.
Waj2005, I understand that you merely replace the old diodes with the same 1N4003 (maybe a wrong interpretation).
I also find a very interesting thread here, Digital Drive: Tweaks for Rega Planet, the long, unabridged version by Carlos where Schottkies are recommended.
I'm just wondering why Schottkies are recommended, and if 1N4003 or 4 would do a similar job here. I'm suspecting that replacing with the same part may turn the issue to come up again... but on the other hand, 1N400x are so much more easy to find.
I would appreciate your guidance before I open the player.
Thanks...
