Rega Planar 3 Acrylic Platter Drawings
Hello,
do you know where I can find the drawings of Rega platter?
May be 12 or 15mm thick?
I'd like also to know if I can use the platter as belt pulley?
My motor have a electronic speed control.
There is any stability problem?
Guglielmo
Hi.
Try CSownsnazzy's website if it's still up and running. There's a drawing on there for a 25mm thick acrylic platter. Made one for my Planar 25, no problems with stability. or anything else for that matter. Make a record weight as well for best results to decouple the LP to the platter.
John J. R.
