Hi all,
I'm making a DIY TT and am getting close to the finishing stages. Its along the lines of a teres 360.
I need to make a decision soon on the motor. I am looking at 2 choices:
1. Use a floppy disc drive as a motor. I have spare drives and can make up the drive easy.
2. I also have a rega P3 motor ( I bought a P3 TT from ebay for the RB300 arm). As far as I can tell (haven't actually received it yet!) it has a AC synchronous motor. I can build a PS like the Naim armageddon which I've already done for my ariston RD 80 (LP12 clone) with good results. This may be the easier option for me.
So I seek the opinions of those who have experience of either or both of those drive options above..... Which should I go with????
TIA,
Fran
TIA,
Fran
Since you have the Rega Motor, why not explore that route?
Its designed for smooth operation and if it does not prove successful, you can then proceed with the Floppy drive motor option.
fran-
give me a shout; i may have-or can get-a teres motor that'll do the trick. let me know...
-barry
-barry
fran-
here's another possible i came accross online:
http://www.canuckaudiomart.com/deta..._for_vpi_scout_with_the_pulley_and_capacitor/
-b
-b
your building a turntable and you've bought a P3 ?
As its an AC synchronous motor :
For the P3 motor pulley you need the P3 subplatter,
for the P3 subplatter you need the P3 main bearing.
There was a kit years ago (german I think) that
used all the bits of a P3 to build a Roksan-u-like.
i.e. it consisted of a split plinth with isolators.
🙂/sreten.
🙂/sreten.
Hi Sreten,
I know, it sounds confusing. You see what I really wanted was a tonearm.... but when you look on ebay, a tonearm on its own always fetches high money.... So what I did was I bought a P3 turntable that was missing the glass platter and belt, but did have a RB300 arm fitted that was in good nick (I hope). Becasue it looked crap on the auction, it came cheap in the end! So thats how I've ended up with the P3 bearing and motor....
I know about the matching of pulleys, but I can make my own pulley to suit, so that doesn't matter too much.
I've also made my own bearing thats kind of a cross between the well tempered and the teres, actually turned out quite well!
Fran
Fran
