Rega ELEX runs hot
I have just bought a Rega Elex, which works well - although the speaker relay needs a clean/replace as the RH channel only comes on if the volume is pushed a bit, but once on stays on.
It does run quite hot though - feels very warm to the touch.
A thermometer placed on the case reads 38 degrees C.
Is this normal for this amp???
Thanks😕
