Record cleaning?
alternative
I have been using the knosti for over 25 years now. It does work and is the cheapest solution.
The next step is nokki nokki, I bought one recently and it does a much better job. If you have a lot of records in the end you will save on fluids by using this device. The NN is noisy and has a lower WAF.
regards
E&E
I am going the diy route, hope to build it this weekend.
I have an old, non working turntable I will use. I plan to use my shop vac for the vacuum, will cut a slit in a crevice tool, and line the slit with felt or something similiar.
I bought some record research super vinyl wash, and the disk doctor pads to actually clean the records with.
Since I had the shop vac, and the broken TT already, my investment is about $20 for the disk doctor replacement pads and $30 for the super vinyl wash. And $5 for the crevice tool.
Hope this works.
Randy
