I am trying to get recommendations for a rock solid phono pre-amp design for integrating into a Pass Labs First Watt B1 bufer/ LM3875 Chip amp combo for use with a Technics SL1210 Mk2 turntable with MC cartridge. Ideally I'd like to be able to use it with a MM cartridge as well down the road, though it's not critical.
It's really hard to find something that's really highly recommended and has been put through the paces and improved upon. I need that because although I love making electronics, I'm lost when it comes to designing or improving upon the designs. I basically like making kits.
Many thanks
Lucas
Many thanks
Lucas
hi
designed by john Linsley Hood, gain adjustable MM or MC carts, pcb or kit availible, i use this circuit myself sounds nice. the pcb looks good from these guys and price looks ok too.
Circuit (bottom of page 1450 phono)
http://www.angelfire.com/sd/paulkemble/sound3.html
PCB/Kit
1450 Phono Stage
i have no connection with this company.
PCB/Kit
1450 Phono Stage
If you can get the circuit somewhere to make yourself, the Tom Evans Microgroove or Microgroove+ a British made solid state phono stage left all others in it's wake at our Audio Society phono stage comparison, it sounded big and full bodied like tube but with the detail and control of solid state, it was truly head and shoulders above the others.
Cheers George
Cheers George
It looks nice, but I think putting tubes into this particular integrated amp may be a bit of a mishmash. Besides, it's expensive and from what you say, MM only, whereas I've got an MC cartridge (on the Technics SL1210 Mk2 I have bought but yet to collect).
Thanks for the heads up though!
Lucas
hi
A Paul Kemble web page - John Linsley Hood preamp designs.
PCB/Kit
1450 Phono Stage
Now this, Burbeck, looks bang on the money! Many thanks indeed. Unless Nelson Pass decides he wants to give me the design to his new all singing RIAA stage, I think I'll go with this. I looked up J. L. Hood in Wikipedia, and it seems he was an English nuclear physicist, among other things. It will be good to get some classic British-ness in my amp design...
Many thanks again. If you can advise me about the build or substitutions you've made, please feel free to do so.
Lucas
Anybody got the Tom Evans Microgroove schematic that George mentioned ?
The link to the product site is: Tom Evans Audio Design-USA
Best regards,
Bins.
Best regards,
Bins.
Cheers George
Sounds like you've heard a few and this was the best, but I can't find a clone anywhere (in a fairly cursory search, I'll admit).
Thanks for the recommendation
Lucas
😱😱😱😱😱Now that's dedication!
I'm still looking...
...the John Linsley Hood phono stage kit is £110 and £75 for the power supply, making £185, which is just too much for a kit right now. My turntable, a Technics SL-1210 Mk2, was much less than that.
Any more suggestions?
Try Bugle phono stage: Hagerman Technology LLC: Bugle Opamp Moving Magnet Budget Phonostage DIY Kit
Best regards,
Bins.
Best regards,
Bins.
FWIW, I've been very happy with circuits similar to what National published in their app notes for the LME series of op-amps when they introduced them.
I have been researching different solutions and concluded that opamps produce much cheaper, reasonable quality products, but that the very best hi-fi designs are fully discrete.
How true is that?
How true is that?
Condensing a huge topic to a few sentences, there are a couple philosophies. High gain with significant negative feedback. Low gain with less negative feedback. Commercial opamps will have huge open loop gain and operate with a lot of negative feedback. Much audio mythology says this is bad. The hallmark of most discrete design, other than power amps, is simplicity and low gain, coupled with lower amounts of feedback. Much audio mythology say this is good. You have to decide what your definition of good and bad are. I believe you'll find Pass designs fall into the simple, elegant and low feedback group, and people certainly have high regard for them. Personally, I tend towards high gain, high negative feedback and low distortion. Hopefully without odd harmonics and the errors of the past. There have been plenty of bad opamp designs, but today we have parts that need make no apologies. IMHO, there are multiple paths to get where you want to go.
Conrad, you are partly right. If you have an one opamp solution the feedback will not be very high, sometimes even to little to achieve an accurate RIAA curve.
Try RETRO from twisted pear audio. The link is: http://www.diyaudio.com/forums/twis...fully-symetrical-phono-stage-riaa-filter.html
Best regards,
Bins.
Best regards,
Bins.
I have settled on the "Atlantis." It is a single ended, Class A, zero feedback RIAA Phono pre-amp, by Mads K Hoaas. Here's the schematic for the MM version, which I am making:
I have PCBs on the way
I like that it is discrete, as I'm inclined to be suspicious of op-amps, even though I have them in my DAC and I am largely ignorant as to why they are less desirable for hi-fi than discrete solutions.
A simple and accurate Phono Preamp design is available at: http://pdfserv.maxim-ic.com/en/an/AN1931.pdf
- Analogue Source
- Recommendations for Phono Stage (RIAA?)
