[I hope this the right forum for this question.]
My current desktop set-up is a FX-Audio DAC X6 connected to a Lepai LP-2020A+, which drives a pair of Minimus 7 speakers. I'm looking for a recommendation for a cheap (max $60, preferably less) replacement for the Lepai amp. I know which end of soldering iron to hold, so a kit is a possibility if it's not terribly hard to build and bring up.
I have searched here and elsewhere and have seen a number of suggestions:
Thanks!
- Breeze Audio 3116 unit (I think this is also sold under the "NobSound" label)
- SMSL 36A
- SANWU® HF183 TPA3116 (board with remote control)
- DAMGOO Bluetooth 5.0 Amplifier Board,100w (board with top & bottom plate)
- Volt Plus or Volt
- a few Weilang TPA3116 amps available on AliExpress
Thanks!
AIYIMA TPA3251 Digital Audio Amplifier HIFI Power Amplifier 2.0 Home Mini Professional Amp NE5532 175W *2 Super TDA7498E/TPA3116| | - AliExpress could likely reuse your existing power supply
edit: just saw the lepai is a measly 12v, that wont cut it, Amplifier 32V 5A Power Adapter 32V DC Power Supply For TAS5613 TPA3255 TDA7498E Bluetooth Digital Stereo Audio Amplifier DIY| | - AliExpress however it puts you a smidge over your budget, but its a great combo
I'd upgrade the speakers first, having had them before, maybe a good used pair found locally.
