Recommend an amp for electrostatic speakers 1.2 Ohms
Hello folks,
Does anybody have an amp (module) recommendation for driving the panel section of a hybrid electrostatic speaker? It has the high-pass circuitry already built in, so that means the amp does not drive the transformer directly. There is a (small) series resistor and DC blocking capacitor in the way. The impedance is higher at lower frequencies and only drops to 1.2 Ohms at 20 kHz. Preferably I would like a unit that can do 100W or more into 4 ohms.
Hypex amps handle 1 ohm impedances without trouble. The NCore is the top one, but the cheaper UcD modules can also handle 1 ohm loads.
Hypex Electronics BV - Home
NCore400 data sheet: http://www.hypex.nl/docs/NC400_datasheet.pdf
UcD400 data sheet: http://www.hypex.nl/docs/UcD400HG_datasheet.pdf
(See "Recommended operating conditions" for minimum load impedance)
Both of these should have you covered comfortably in the power department and should sound great as well. Some DIY required though, mostly just connecting stuff together (PSUs, cables and such are also available from them).
