would it be an improvement to reclock as well the data line of my non-os dac or just leave it alone?
Toni.
Toni.
tonitze said:would it be an improvement to reclock as well the data line of my non-os dac or just leave it alone?
Toni.
Hi Toni,
We did that in our oversampling DAC (PCM63K based), and it made a minor improvement.
The result will depend on the DAC chip used. Which one do you use ?
We actually setup a listening test where we could choose which line to reclock or not.
That was about 6 years ago
I'd say go for it
tonitze said:Chips used were cs8412 with Tda1543.
Thanks.
Hi
Could have guessed that....
No experience with 1543, but just give it a try
Inspiration can be found here
http://members.chello.nl/~m.heijligers/DAChtml/dactop.htm
go to technical overview and then schematics
succes
tonitze said:Are 74hc74 good enough for the assyn. reclocking?
Hi
depends on the clock frequency
