Reccomended amp?
I am new to this DIY audio
I have a pair of 120w fusion speakers (40w at 6ohms) which I'd like to run from a mini amp
I'd like to use an 18v battery to use it portable but with an SPDT switch to switch inputs between the 18v battery and a 19v laptop power supply
Ideally would have bluetooth aswell
Could anybody reccomend an amp/board to use? Thankyou
EDIT **I have just stumbled across this board "TDA7492" which says its 2x 50w at 6ohms, also has a cooling fan on the chip
Hi Fleck91
if it is ok for you look at a Class D (other forum) an look at this board.
Sanwu TDA7492P + Bluetooth 2.1
chris
