recapping Pilot 232
Bruce,
The Miflex KPCU-01 would be excellent, but they may not fit (be sure to check the dimensions) without a little engineering. The KPAL-01 would be great on the cheap, but they are the same size. They are currently on closeout, so get them while they last.
Absolutely has to drop in without modification, use the AZ Blue for the interstage (0.047), and the AZ Red for the outputs (0.10).
