Recapping Focusrite 315 mastering EQ
Hello!
Left (upper) channel on my 315 recently died but for some reason works when I short hot & cold on the output - which in its turn offsets balanced gear down the line. The following item loses 5-7 db on the left channel. I guess my short circuit makes it semi balanced, or something like that?
I will figure it out!
Anyway, since it's a 25 year old beast filled with ~60 Nover 16V 100 uf caps per channel I thought I might as well recap it. Actually it doesnt use any other cap than those Nover 16/100. In & out level stages, eq stages = all Nover 16/100. The power supply use two Nover 50V 4700 uf and one 16V 4700 uf.
Any tips on what to use instead? What cap would be suitable for audio and an upgrade. I'm looking at Elna (on Mouser) RFS-16V101MH3#5
Elna are 10 mm diameter instead of the Nover 6 mm but should fit. Spacing between legs are 5 mm on both the Elna and Nover.
Or would you recommend anything else?
(the 315 also uses a lot of Philips NE5534N opamps 🙂 )
