I got something returned to me that I never thought I would see again. A Sansui S-x1130.
The problem, VERY little information is on the internet about it. It's rated at 130 watts RMS at 8ohms, weighs a ton, and that's about all I know.
I havn't been able to find a single review on it, nothing. The sounds comming from it are very nice, but is it as good as some of the classic, more popular Sansui amps?
Sansui S-x1130
RATE THIS RECIVER;
GIVE FOUR 1/2 OUT OF FIVE.
REASON,S
BOUGHT NEW 1989 STOOR DEMO@$295.OO NEW LIST POUPLER ELECTRONICS $1995.00.CAME WITH BOX&OPT BOOKLET,
+ STABLE/STILL USING,TEST SPEAKER,S/CROSS OVER Hz,WITH OSCOPE-
60 MEG.DUEL TRACEE X TRIGGER TO ADJUST CAP,S7CHOKES IF CORRECT,
+-2 CLEAN AMP LOW DIS/.O2 AT RATED OUT PUT,
+-3 SN PREE AMP AND POWER AMP SHORT INPUT. TURN VOLUME ALL UP
PUT EAR TO SPEAKER(NOTE JBL-O75 TWEEETER,S/
+-4STILL ON SHALFT BULT FOR IT ,NEVER HAD TO SERVICE,
OR REMOVER COVER NOT EVEN TO CLEEN VOLUME OR TONE CONTROLS.
NOTE AMP DOSE PUT OUT POWER WHEN YOU CRANK IT UP(BEON BARGRAFT DISPLAY/HAVE RIPED WOFFER CONEC APART WHEN TEST NEW AGEV SKEAKERS TO USE AS REPLACEMENTS FOUR,OLDER SPECKER,S BOXES,
FOUND WOFFER TO REPLACE [JBL MODEL L40 1970-80 SPEAKER]
BELIVE SOUND BETTER THAN JBL MODEL 127A,
REPLACE NON CAST FRAME BUT WILL FIT WITH NO ADJUSTMENTS/YES MEASURE 10" NOT 10-1/2" AS CAST JBL USE SAME GASKET THAT COMES OUT /WHEN REMOVE 127A SPEAKER,ALSO CLIP WIRE END CRIMP NEW CONNECTORS WILL BE USED/ALSO CONFIRM +& - ON NED SPEAKER I USE D CELL BATTERY WHEN CONE MOVES OUT THIS IS SPEAKER + REGARDLESS
OF MARKINGS,NOTE REPLACEMENTB SPEAKER/CLOFT ROLED EDGE/2" VOICE COIL,CONE PAPER THICK(CLOSE TO WHAT USED IN JBL D-140'S/POWER RATING 250 WATTS PEAK/125 RMS-COST LESS $80.OO FOUR A PAIR,
RECIVER HASPREE AMP OUT PUTS AND INPUTS,USE TO TEST POWER AMPS
WILL LET MAC MC-30 OR MC-60 TUBES AMPS SMOKE ALSO GOOD FOUR ANALOG TRANISTOR AMPS TO COMPAIR AND BURN IN-ADJUST SCRINE GRIDE BIOUS/CLOSE # EL-34'S TRY 37 VOLTS/6550 47 VOLTS,
GOOD IDEA REPLICE SELIMEN DIODE 1,000 VOLT PIV@3 AMP (NOTE WHEN GRID BIOS GOES UP,REASON FOUR BASE BIOS VOLTAGES #'S MAY NEED TO ADD REISTOR 1K-?,TO COMPLET INPROVMENT TO TUBE AMPS THIS LOWER DISTORION ALSO REPLACE FILTER CAP 40 mfd-use vaul in amp/
this is sure fix on tubes amps when insize tube GLOO'S RED---
NEG ABOUT RECIVER S-X1130 LACK BASS FOR THE TRUE HOUSE SHAKERS
BUT POLLICE MIGHT BE KICKING YOUR DOOR(TO ASK YUO TO TURN IT DOWND)
NEG SOUND NOT THE SAME AS OLD TUBES AMPS WARM DEEP BASS,
GREEN ALTECTS RACK MOUNT 4 EL-34 AMPS,IF YOU CAN GET THEM WILL
IN MY RATTINGS BESST SOUNDING TUBE AMPS,NEXT SCOT MONO AMP AMP SAME OUTPUT SET UP SET FOUF EL-34'S/BOGEN ALSO MADE AMP
SAME OUTPUT STAGE/IF CAN GET ONE YOU WILL UNDER STAND-
NEVER THOUGHT WOULD SELL MY MAC MC-60'S/BUT THE GREEN ALTEC'S
WASTED THEM WITH AS CLEAN AND WARM SOUND BUT LOULDER,
ENJOY THE FUN OF GOOD CLEAN AND LOUD MUSIC,
THANK YOU;
YOUR FEED BACK WELLCOM
4ROB
RATE THIS RECIVER;
REASON,S
THANK YOU;
4ROB
