Rackmount Powerstrip Controller
This piece of equipment needs to find a home.
Rackmount Powerstrip with Master Switch
This is a custom built powerstrip with AC Voltmeter and Master Switch. It features automatic power up. It has 10 AC outlets (2 Fixed + 8 Switched). It was built to automatically switch on a rack of audio equipment.
How it works: The 2 Fixed outlets are unswitched. Whenever you turn on any device that is plugged into these outlets, the unit senses the current draw and will turn on the other bank of 8 Switched outlets. There is a defeat switch on the front panel which kills the switching function should this not be desired. In this mode all outlets are powered on all the time.
* Digital Panel Meter Monitors Line Voltage
* High Quality 15AMP Breaker Switch (Front Panel)
* Solid State Relay Switching
* EMI Filtering + Surge Protection
* Teflon Wiring
This controller was built around a high quality HP equipment case. There's lots of room inside if you want to put in a toroidal isolation transformer to isolate certain pieces of equipment from the mains or EMI/RFI filter.
Pics here...
http://pg.photos.yahoo.com/ph/northerngiant/detail?.dir=/bbb7re2&.dnm=a85are2.jpg
http://pg.photos.yahoo.com/ph/northerngiant/detail?.dir=/bbb7re2&.dnm=8145re2.jpg
