What kind of wire/connectors should I use between the PSU and the driver?
Does it really matter?
David Levinson from Supravox America recommended: "16 gauge thermostat wire from Home Depot which is solid copper in a
strong jacket, designed for use inside walls of houses. It's a little stiff, but works well. You could also use home appliance wire (stranded copper) if you wanted something more flexible, but its quite a bit more expensive",
