Hi all,
I have an old Pioneer LD player model CLD-D580, which uses a DA chip PD2026B (28 pins). I do not have the player's schematic & the chip's data sheet.
But i would like to find out which are the Vout pins for the L & R on the DA chip.
May i know usually where are the Vout pins go to (which component)?
Thanks!
Thanks!
hi assyst , i only have pinout for PD2026A , likely pincompatile , it is 1bit stereo DAC with balanced Vout on pins 9&10(LO) , and 5&6 (RO) . Agnd is pin 8.
hope this helps ,
hope this helps ,
Hi guytou,
Thanks for the info.
I think PD2026A is close to PD2026B (i hope). I got info for PD2028B but it's different from my PD2026B.
