In the attached schematic, why are there two Vo (voltage out)?
I am assuming the top one (without CR) is used if directly coupling to another circuit, e.g. an op amp, and the latter is used if "going out", say to output jacks that then would go into an amp. If this is true, what is the suggested CR doing in this case ?
Btw, the schematic is for a line level audio switch.
Thanks! This is one of the best sites on the Internet !!!!
Ok, the RC network is a high pass filter, BUT why is it needed in only some cases, and what are these cases? Also, what would be the difference if it was done with a 22k and 10u ?
Thanks !
Thanks !
This would be basicly the same in regard of frequency, but it would be a lighter load.
This filter is needed for blocking some unwanted frequencies.
The capacitor blocks DC and passes AC. The resistor grounds the output and provides bias for the capacitor, as electrolytic capacitors need a suitable voltage across them to maintain the dielectric. Whether you need this network depends on what comes next. Generally, external signals should be referenced to ground but internal signals do not need to be.
This combination of R and C forms a high-pass filter and so sets a low frequency limit. The corner frequency is given by f = 1/(2 pi R C)
The IC has a single supply. My guess is that the output and input pins are biased to about 1/2 of V+. As already stated, the capacitors block this DC bias to allow ground-referenced signals to be input and output.
Thanks everyone !! I think I am getting this...
On the "lighter load using the 10u" aspect, what difference does this make? When driving the amp by the words it would seem to be a better situation???
O.K imagine that this 1k resistor is a short to ground.A short has no resistance at all, so it will be a very "heavy" load for amplifier.Of course it's better for him if there is a big resistance to ground.Then dependent on what circuit you will connect it will have also some impact on the load.
That schematic is labelled "TEST CIRCUIT" ie how the chip may be tested. It does not necessarily have any value as an APPLICATION circuit!
cliff, it;s the only circuit provided in the datasheet - it works - just trying to understand it (obviously the switches, etc. are for testing and not applicable to my app).
Leon, then why not use a huge resistor and have a very light load? What are the ramifications of this ? Do you want a heavy load to the amp? By wording I would think not, but I don't understand it 🙂
Source and load resistance levels are compromise - like most of engineering!
A low > zero output impedance is "good" but very difficult for a tube amplifier and has to be current limit protected otherwise. In practice, up to 1K to 5K is reasonable and easily done.
But now there is a finite Zout, the roll off of turn-over frequency with a series C has to be considered!
High Zin seems good but renders the amp much more likely to hum and noise pickup, requiring screening etc. In practice, 10K to 100K is livable with.
So a 1K out, 50K in would be pretty ideal, other things being equal.
what does the description say that this chip can do?
I think the switches on the 3 inputs are there for testing only.
I think the chip has 3inputs and 1output, does the datasheet say how the 3inputs are switched?
What do you not understand?By wording I would think not, but I don't understand it 🙂
That's very easy.The current always goes the way of the smallest resistence.So if put a 1k resistor to ground then some current, not all, will go through him to ground, but if you put a 1R resistor to ground then almost all current will go to ground and it will be like a short.
This all works fine in my controller. The switches are voltage high/low binary. The ic is 58k ohm input and 10 ohm output.
I meant why not put a 1M ohm, so all the current goes to the amp? Is it just because the capacitor would be too small ?
Maybe because of capacitor or some other reason.I don't know for which purpose they intended this filter.That all depends on the purpose of your circuit.
Then only a very small current will flow through the resistor. This could be less than the leakage current through the capacitor, or less than the leakage current of the input pin of the amplifier (or opamp) following this circuit. That can and will cause a DC offset which, if you have no other DC blocking downstream, can blow your speakers, overheat your amp, etc.
Besides the possiblility of a steady state DC offset, you would likely get "thumps" when switching inputs, etc. This due to the extremely low cutoff frequency of the high-pass filter formed by the R and C. Fc=1/(2*pi*R*C). Even with the values suggested (220uF and 1kOhm) you get a transient lasting about 1/2 second before falling to 10% of the initial value. With a 1 Meg resistor (and 220 uF), it would last 1000 times as long... about 8 minutes. I'm not kidding.
Any value is a compromise as already pointed out.
But why he needs this filter at all? An amplifier has already an iput filter.
That's kind of my question... Wouldn't an amp always have dc blocking caps??? Why wouldn't it?
I've tried the circuit with and without it, and I don't see a huge difference. I think without it some dc is getting processed by the amp because at high volumes the bass handling seems a lot worse.
It is NOT a fliter!
Th cap is a DC block, the R is a ground level restorer.
Always needed if it is NOT known what is plugged into it! If you can control it and there is an input cap then not needed.
It is NOT a fliter!
So why wouldn't all amps just have dc blocking caps on the inputs???
- Analog Line Level
- question about this schematic ?
