Question about TDA2030+BD907/908 amplifier
Hello
I made this amplifier, and since I don't have testing equipment thus cannot experiment with values of components.
So, I wanna ask what is necessary to lower the input sensitivity, because current input sensitivity is around 470 mV, and I need for input signal around 900-950 mV?
Adding a resistor on signal input or changing the values of R2 and R3?
Thanks for quick reply.
That make sense because R3 is negative feedback and with lowering this resistor, also will lower the gain of amplifier, and this will allow higher input signal.
I thought that experimenting with this resistor will do the job but I was unsure which value is enough for.
According to the data sheet the minimum closed loop gain must be > 24dB = x15.8 approx (bottom of Table 2 page 13/15). However the example circuit in the Data sheet (Page 6/15) shows values of 30k and 3.3k which equals a gain of just slightly greater than x10. ?? Maybe the presence of the booster transistors makes a difference.
