Question about port size conversion
None the less, if you do decide to retune your ports, here are some links to port length calculators that you can use.
Box Tuning Calculator -
http://www.2k4civic.com/portcalculator.html
Linear Team Vent Calculator -
http://www.linearteam.dk/default.aspx?pageid=ventcalculator
Calculate Your Vent Length -
http://www.carstereo.com/help2/Articles.cfm?id=31
(scroll down the to second calculator)
Port Length Calculator -
http://www.the12volt.com/caraudio/boxcalcs.asp#por
You can also use these calculators to determine at what frequency you are currently tuning your ports.
Just enter the port diameter, internal box volume, and keep changing the desired tuning frequency until it gives you your known port length.
Just trying to help.
Steve/bluewizard
