Question about LED voltage capacity
The resistor (10k in your attachment) limits the current through the LED to a safe value.
Depending on the supply voltage, you might want to change the resistor value to adjust the brightness.
btw: Normal LEDs are rated for max current, not voltage.
Some have built-in resistors, flasher circuits etc but I doubt you can hurt any of them with that circuit.
