I have been thinking about the flare rate of multi entry horns at the tap point
Is there a way of calculating the flare frequency for each point down a horn flare?
I saw somewhere that it could be done with this formula:
343/(4*PI*L12)*Math.log(S2/S1)
I am currently making a webpage to help with designing MEH, you can put in S1, S2, L12 then it will graph the highest frequency, cancellation notch and hopefully lowest frequency loaded by the horn at each tap point.
This is where I am at so far:
Doesn't look great but you can upload the slices output by ath or generate a conical horn
