My question arose because of two models of amps by power acoustic
power acoutsrik rz5-2500dsp 4x100+400@4ohm
power acoutsrik rz4-2000dsp
4x190@4ohm
My question is in regards to the rca connections. The rz4-2000dsp (4 CH) model features a rca out, and can be controlled by the dsp chip to give dsp features to external subwoofer amp likely thru the sigma studio software used to control the amp. The model I purchased rz5-2500dsp (more expensive) model lacks the RCA output port altogether. The other RCA connections are inputs for front and rear channels from the deck.
My question is what RCA would you recommend running if using a modern pioneer deck like dmh-220ex? The deck also features dsp options aswell. Does my model lack sub channel inputs or is the rear mixed with sub channel? How likely is the 4 CH amp able to control this RCA out? How feasible 2ould it be for me to solder in RCA inputs for sub channel? Or RCA out, like the 4 CH version has?
4x190@4ohm
