Hello,
Just found this schematic:
http://www.diyparadiso.com/othello1.htm
Does anybody know what are the benefits of using an EZ80 tube rectifier just after the silicone bridge?
reaction said:Hello,
Reaction,
The IDH rectifier as is EZ 80/81 will provide slow start for the B+ which could not be provided with SS diodes.In other words, without that rctf. the signal tubes will suffer from cathode stripping,because B+ will be applied before they get warmed!
Regards,
Yugovitz
Of course, cathode stripping is that fairy tale they tell tube-geek kids at night to scare them...
Tube or SS. Make up your mind. Use a timer relay if you have to (e.g. transmitter tubes specified for a heatup period).
Also no need for *******' 1mF on a preamp
Tim
Tim
