Sorry, just a noob question about toroid transformer secondary side. It's 65v, 0v and 65v. It's 3 wires instead of 4. Does it mean that the combine the 2 x 0v wires together, that's why it became a single wire??
It’s 130V center tapped, not dual 65V secondaries.
Oh ok, I understand now. Thanks for the explanation!!
If it were 2 secondaries they would connect zero volt of one to 65v of second secondary to get a centre tap.Sorry, just a noob question about toroid transformer secondary side. It's 65v, 0v and 65v. It's 3 wires instead of 4. Does it mean that the combine the 2 x 0v wires together, that's why it became a single wire??
There really is no 0 and 65v wires since it is AC. From one end to the other is 130 volts AC and they took a tap wire at the half voltage point which is 65 volts relative to each end. If there were four wires you would have two separate 65 volt AC windings. You could join them together and have what you have now.
Thank you for the explanation!
