I do believe the transport on my Quad 99 CDP (1st series, SN1650) is dead: the disc loads, the laser head tries to focus 3 times, but at no point in time the disc does spin: as if the motor was dead.
the laser LED seems to emit a signal(can see some red..).
How can I fully diagnose the issue, to define if the pick up is to be changed or if the full transport should be swapped?
and where to find parts?
thks
thks
well, I could find this CMD 12.4 in Ireland: I'll try a replacement, and worse case, I'll let the 30 euros go...
Audio Spare CDM12.4 (CDM 12.4) - CDM12.4 / 05 / 691.30354/CDI210 / 40...
On this mech, the first thing to always check for is platter slippage, meaning that it's not unusual for the platter to slip down the motor shaft, causing wrong focus distance & often making the platter drag on the chassis.
