Quad 57 trouble shooting
I've owned a pair of 57's for about 30 years, and had them rebuilt about 5 years ago by Wayne Piquet. A long term love affair. But recently one of them sounded muffled, and when I checked, the power supply light was out. Pulling the plug made no difference, so indeed it's not getting powered up. Frankly I was surprised it played at all. Any ideas before I start taking things apart?
The 57 uses a remarkably simple circuit without much of the safety frou-frou of more more 'modern' stuff, so they're simple to debug and work on.
OTOH, they'll also electrocute your pets or burn down your house with a rather casual British indifference to the consequences...
If the neon glow lamp is out, there's no AC voltage reaching it - start at the wall socket, confirm AC, then check the supply cord for continuity (the silly 3-prong round 'Bulgin' connectors can fail at either female or male ends...), and finally check across the 57's power supply input pins - there should be 8-12 Ohms resistance.
Open (or infinite) resistance implies either a bad internal connection or an open primary in the transformer - here's a link to a schematic for the older 57's:
http://tinyurl.com/osydmuo
And one to the a pretty complete document on rejuvenating the beasts.
http://www.quadesl.com/pdf/quad_book.pdf
Cheers & good luck
Jim
Thanks Jim. For reasons not clear to me, reversing polarity, i.e. flipping the wall plug 180 degrees, cured the problem. Perhaps that means the cord is going intermittent somewhere and I just jostled it back into contact. For now, I'm happy again.
