quad 520 help - noise when turning off
i have a quad 520 power amp and recently moved - now when i turn off i get a farting crackle noise on the right channel, instead of the usual pop.
Plays fine.
I looked inside and the T2A fuse on the right channel has blown.
I've ordered a new fuse so will see what happens.
Just wondering what people think - could it be a one off or will it blow again? (i guess i'll find out when the fuses arrive)
i have a multimeter but not a lot of knowledge in this area.
I can't see anything else untoward on the inside.
thanks
A centre tapped transformer provides a voltage reference for a split rail power supply
+V 0V(or voltage ref) -V Are there fuses on the +V and -V feeds as well?
Below is from a Google search.
A center-tap transformer is designed to provide two separate secondary voltages, VA and VB with a common connection. This type of transformer configuration produces a two-phase, 3-wire supply. The secondary voltages are the same and proportional to the supply voltage, VP, therefore power in each winding is the same.
According to the manual the only fuses inside are the T2A ones and T6.3A - the latter are near the main power supply (for 220v).
i don't know much about electronics or amplifiers, but i just found it odd that a fuse had blown and the only consequence was the noise on turning off.
The person who told me it was centre tap could have been wrong.
Looked at the schematic --there is no "fuse in the centre tap" as there is no centre tap shown in any case.
One input fuse,
One HT (before FW rectifier ) fuse.
Thanks - i guess the guy on another forum was wrong then.
I just remembered, and i'm not sure why i didn't connect the dots here, but after i moved i had no sound out of the right channel and i found it was the speaker cable (they were home soldered into an xlr plug and one of the connections must have broken in my move).
I guess this could be responsible for the fuse going?
Lateral thought here: A guy who describes a fuse (no mention of transformers) as centre-tapped is probably looking at the fuse wire inside the glass tube and realises that many "T" types have the fuse wire supported by another, rigid wire at the centre. Hence, he sees it as centre-tapped.
This is how many "time delay" fuses are constructed and for loads like amplifiers that have a high surge current at start-up that would blow a standard fuse if it were correctly rated to protect the amplifier against overloads.
thanks.
yeah i showed the schematic to a friend who can read these things and he pointed out the centre tap to me so it definitely does have one.
i still find it odd that the only consequence that i could tell was the sound on turning off - is this normal and what you would expect?
cheers
i think thats the 520f - they look quite different inside.
here is what dada says:
The 520 differ on two major aspects from a 520f, a double conventional power supply instead of the power supply with the regulated earth to prevent any DC current through the loudspeaker, and discrete build current sources in the input circuit.
i don't know what significance this has.
When you swap the left and right loudspeakers, is the farthing sound still in the same channel?
I'm asking because of a problem with a Klein & Hummel OY active loudspeaker that seemed to be due to one of the built-in amplifiers, but in the end turned out to be due to the squawker's voice coil being disconnected. Multiway loudspeakers with a broken-down driver can present a very nasty load to the amplifier that may cause audible oscillations, either all the time or at power on or power off. It took me quite a while before I had the issue figured out.
The OY produced a weird squeaking sound at power off. Of course it also didn't work well when powered on, as its squawker didn't work, but the weird sound at power off was noticed first.
now i replaced the fuse everything is fine and the sound is gone
Thanks for the link Aardvarky provides a lot of schematics ,now I see the version you have is the center tap transformer type .
£100 for a Quad 33 ??? --I had trouble selling mine decades ago as it wasn't exactly top end fidelity--times change.
I notice the article recommends getting the 520f but as I surmised a whole shop load of variations on the basic design .
Some good advice on updating them , I have to say I had never heard of DADA but they are a lot more open on providing schematics and conversion info, many commercial businesses aren't as open as that trying to make updating some kind mystery only the cognista can achieve.
