Quad 405-2 repair
Hello.
I accidentally bought a faulty amplifier Quad 405-2. The repairman diagnosed it. It is necessary to change the OPA and a strange detail with 5 contacts. Which is not sold anywhere. I enclose the photo details. Tell me, can you buy this part?
Hi aspiens,
I have never seen one bad in my life. If it is truly bad and you can see what it does from the schematic, your repair person might have to make one. I have done that with various sealed modules in Luxman equipment before.
-Chris
I think it is a weird kind of protection circuit, but I also think the amp should run with it removed... I'll look a little closer at that though.
What fault does the amp actually have ?
It looks to clamp the drive in the event of an overload by pulling pin 4 to pin 1.
If the amp is OK apart from this module then I would say it should work normally with it removed.
The module as drawn also seems to have a major error with one of transistors shown as PNP when it should be an NPN.
I took the amplifier to my repairman. He said not to put these assemblies. Remove altogether. New output transistors Motorola 15009 instead of the damaged. New opa amps OPA604. I hope everything will be fine and the amplifier will work as expected.
There is another question.
I have one more working Quad 405-2. Very strong click in the speakers when turned on. I'm afraid for my Tannoy Berkley.. How is it to win?
I'm not actually familiar with the 405 in use and so can't say how much of a switch on noise you would expect. There is no speaker delay facility and so some noise is going to be normal, and that will appear much worse with high sensitivity speakers.
There were also many versions of the 405 throughout its production run and so it would only be fair to compare like for like.
