Hi, I wonder if anyone can help me with this. One of my boards M12565 iss 6
has blown R38. When switched on the resistor glows bright red at which point I switch off! I've read the Quad service data and have checked D5 and D6 which it states may cause the problem. I unsoldered them and they are fine.
I'd be grateful for any assistance with this.
Thanks for looking
Peter
Thanks for looking
Peter
Also check R7 and R8, they are rated very conservatively, and should be replaced with metal oxide resistors of (at least) 1W.
I would disconnect the DC offset protection by unsoldering the blob next to the output terminal then check the output offset voltage, this should be a few mV. The CD protection triac goes s/c. Then I would check both supply voltages and the supplies to the opamp.
Stuart
Stuart
