QUAD 405-2 C2 polarized or bipolar cap?
I have several Quad 405-2 amplifier which I’ve done the usual recap on. I always go with the usual TL071 OPAmp. I have always followed DaDa electronics way of fitting a 100uF polarized capacitor instead of bipolar on C2. They fit the positive leg of the capacitor to ground. I myself usually use low leakage Nichicon UKL capacitors for this position. I recently just thought about if it’s is a good idea to use a Polarized cap instead of the bipolar that was fitted there originally. So, this morning I measured a couple of my 405s and saw roughly 0.2mV on both the negative and positive leg to ground, which seems fine. But what does the collective knowledge here say, should I replace the polarized with bipolar caps instead? Pic borrowed from DaDas 405 revision manual.
My 405-1 comes with 100uf tantalum capacitors, which are polarized. As you mentioned, there is literally no voltage across it during the operation. It is fine to use polarized cap.
PS: I doubt TL071 performs better than LM301 in 405/405-2. LM301 is external compensated with C3 3.3p for the optimal bandwidth. TL071 is internal compensated for unity gain stability, which is sub optimal with voltage gain setup.
