Quad 303 recap
Recently I received a 30 years old 303, it is working and has its original output and PSU caps still on. I am considering replacing with new ones and thinking to raise the original 2K2 microF capacity. I need some help for choosing a suitable value and your opinion about replacement. Moreover checking the voltage value according to Quad service manual, one channel board was showing not stable values, using a multimeter the value keep oscillating fast +/- 0.5/2V, while the other board's values were stable, according to your experience is it acceptable for a 30 years old guy?
As you can argue I am not a professional, but an amateur with good soldering skills and love for vintage equipments.
Thank you in advance for your kind support!
Here is what I picked from Farnell
Capacitors
C100
14 mm
Original .68uF
REplaced with 1uF
uk.farnell.com = 1215470
uk.farnell.com = 1215480
C101
470uF 10V 5mm
KONDENSATOR, 470UF, 50V
uk.farnell.com = 8767440
uk.farnell.com = 9692169
C102
9mm
0.01uF
uk.farnell.com = 1413881
c103
7mm
100pF
uk.farnell.com = 9520660
uk.farnell.com = 1519280
C104
12uF 50V
15uF 350V
uk.farnell.com = 1673477
c105
100pF
uk.farnell.com = 1005979
C106
50uF 50 V 5 mm
Substitute a 68uF
uk.farnell.com = 1281848
c107
3.3pF
uk.farnell.com = 1264865
C108
.1 uF 10 mm
uk.farnell.com = 1606139
uk.farnell.com = 1679359
uk.farnell.com = 1215469
uk.farnell.com = 9752609
c109 & c110
1000pf 7 mm
uk.farnell.com=9752455
Big Capacitors
uk.farnell.com=1198729
RV100
4.7 K
uk.farnell.com = 1227538
uk.farnell.com = 1227568
Trimmer Models 3224 and 3214
RV101
2.2 K
uk.farnell.com = 1227537
uk.farnell.com = 1227566
Regulator
C200
330PF 6 mm 13 mm
uk.farnell.com = 1519286
uk.farnell.com = 1678920
C201
2.2UF 28mm
uk.farnell.com = 1200762
RV100
4.7 K
Heatsink
MJ15003 == 12
resistors fixed value
MULTICOMP
1%
Metal film
R100
220K
uk.farnell.com = 9341552
R101/R104/R108
22K
uk.farnell.com = 9341544
R102
3.9K
uk.farnell.com = 9341854
R105/R116/R117
4K7
uk.farnell.com = 9341951
R106
220R
uk.farnell.com = 9341528
R107/R111/R132
2K2
uk.farnell.com = 9341536
R109/R114/R120/R121
100R
uk.farnell.com = 9341099
R110
8K2
uk.farnell.com = 9342273
R112
39K
uk.farnell.com = 9341862
R113
82K
uk.farnell.com = 9342281
R115
2R2
uk.farnell.com = 9340246
R118/R119
1K
uk.farnell.com = 9341102
R122/R126/R128/R129
10R
uk.farnell.com = 9341145
R123
68R
uk.farnell.com = 9342192
R124/R125
R3
uk.farnell.com = 1108094
R130
150K
uk.farnell.com = 9341340
R131
3K3
uk.farnell.com = 9341749
Owen
