qsc mx1500a
Disabled Account
Joined 2019
I will like to know what will cause my qsc mx1500a to sound as if my speakers is faulty.. this only happen when I load and play the two channels at same time.. if I play any one channel it will sound very well
This is a class-G amp from the description, if each channel is clean at full power it means the power supply is failing to provide enough power for both channels, or the protection circuitry is cutting in and out for some reason (thermal?). Checked the fan is running? Vacuumed out the dust filters recently?
is a while I did.nt give it a dust out.. let me dust it out and clean out the bridge switch
No, because each channel has it's own capacitors.They are actually in a special configuration used only in QSC amplifiers where they provide a virtual ground to the speaker and amplifier .It's a bullet proof system.If you can hear each channel very clear at max power , there's no problem with the filtering.
when you say "this only happen when I load and play the two channels at same time" is it distortion? or is it that it does not sound right?
distortion is self evident but the other condition, doesn't "sound right" could be anything from phase/polarity problems to response anomalies from bad grounds on filters or simply bad solders.
peel the cover clean out the dust bunnies and do a close inspection of all solder points around input connectors and other general things like pulled/misfitted looms or cables or any stress cracks on heavy components.
just to be sure these are the amps we're talking about right....
what sort of speaker and cabinet? these amps have enough nuts to hurt even good drivers when misused.
and likely a language thing but i'm thinking your drivers are running out of excursion (hitting the mechanical limit) this could be helped with EQ or possibly a high pass filter depending on the box design the drivers are loaded in.
don't be shy the more details you supply the better and quicker we can figure out what's likely happening.
