qsc mx1500 1 channel runs hot
im working on a qsc mx1500, repaired some issues the amp was having.
just noticed the channel 2 run hots. At idle with no signal going into it the channel get hot.
probably 40-50 degrees, while the other channel is stone cold,
ive ran it amp sound fine, ran it over an hour, did not have any audible issue.
gotta put the scope on the channel see if i can see anything, i check the speaker terminals for dc voltage, both channels test the same.
does it sound like a bias issue? or what else could cause this?
thanks in advanced
Yes, it sounds exactly like a bias issue. At idle, meaning no signal, it ought not to warm up much more than room temperature.
I am not at my shop, so I can't look it up, but is there not a bias adjust for each channel?
DC on output would warm it up if there was a load. Try it without a load. If it still heats up, then I'd bet my lunch money on bias adjustment.
