Qsc mx 1500 120v
ok now .....costumer has 4pcs of QSC MX 1500 but those are rated 120v each
option one replace a couple of trafos on each amp and you are done
but since 2 trafos exist in every amplifier i could try to wire them in series is this though going to create the trouble that if one of the two channels is loaded then the line voltage on the loaded chanel will decrease while in the other chanel will increase or not ???
advice please
