All of the T/S change with weather. Andwith dynamics.
T/S are vectors, but what we see/measure are scalars after a “measure” point is taken. ie where the vectors ar collapsed.
When i measured for matching i had to measure any driversbeingsorted on the same day.
You cannot tell how a driver sounds by a single number.
dave
dave
I'm glad to see that you have a unique way of writing the post. Now it's easy for me to understand the idea and put it into practice
Maybe I am onto a good thing, designing a working heatpipe/radiator system for my projects. This is the second time I have seen someone bring up driver heating up today. I will be testing out a solid alloy radiator that is fan cooled in a dedicated noise dampened compartment vs a hollow alloy fan forced heat pipe. I have had a bit of experience in making heat disposal systems for marine use electric motors and engines in situations where I wanted to avoid contact with salt water
- Subwoofers
- Qes goes up with temperature?
