I've got a sharp QA-1150 panel with no cables of any kind...no remote, no manual, etc. I saw a post recently where someone mentioned having cables, but I didn't get a response to an email...
Can anyone point me to a supplier for the cables for this panel?
I've also successfully stripped my 15" Aopen F50LS LCD monitor. This is a pretty easy panel to get apart, but will require a ribbon cable extension to be a good DIY solution. The ribbon cable in question is a T-cable that connects a pcb on the bottom and on the right of the screen. In order to get those pcbs out of the way, the cable will need to be lengthened. Doesn't matter for me cause I fried the lcd anyway...but I thought I'd pass it along for others.
hmmm...some leads and some questions
http://diyaudio.com/forums/showthread.php?s=&threadid=4845&highlight=QA1150+cable
This thread mentions pionout mappings for vga cables. Am I correct in thinking these pinouts are accurate across brands for the panels? Will this pinout work for the QA-1150?
http://diyaudio.com/forums/showthread.php?s=&threadid=19218&highlight=sharp+cable
uvodee mentions having cables -- is he still around? if so, I'm interested!!
Finally, it seems folks have been successful in getting power supplies from Radio Shack -- I've got one, but need to know the polarity for this panel. Can anyone tell me?
thanks!
thanks!
