Pyramid R P S not working properly
Good morning,
I went to turn on my PS-50 today and its only producing less than a half volt dc... it did work a few months ago but I did notice that it would make full power. Was a lil over 13.7v rated to produce 15v.
The voltage is somewhat fluctuating several point volts and has ranged from .5v to 1.6v but will go back down. I thought that is might be the voltage potentiometer (knob) as it has little effect... can I bypass it somehow just to see if that was the problem? If so, what value resistor should I use?
Thanks in advance, looking forward to getting this back up and running.
